Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
CALL
JGoode
Hello,
Is it possible to call an object interface if the parameters aren't in the object calling another object?
Thanks
ArchiCAD 27
Windows 10
3 REPLIES 3
No, you can't call an interface to manipulate parameters that your main object does not have.
If I understand your question properly.
JGoode
Thanks, you did answer my question.
I have another similar question. How can I call an object that has it's own interface and then not include any of it in the current object?
Thanks
ArchiCAD 27
Windows 10
calling in the master script would do the trick (see how all the windows and doors in the default library are handled)
Piotr
PS. Sarcasm mode on: I like very much the "bot protection" not allowing to post "so soon" after another 😜
