Learn more
Changing materials
Hi, I´ve built a spiral staircase. I need to change the material but ArchiCAD doesn´t allow me to change these materials (it is set to wood but I need a concrete).
My second question is: Can I build a curved handrail? I didn´t find it in basic ArchiCAD 16 library.
Thanks for help
1 Reply 1
Dwight
You've built the stair using the fill conversion method?
See the attached for stair parameter settings.
For a curved handrail not associated with a stair, try a ramp object.
Dwight Atkinson
