Connection points RFA to GDL?
Hi guys ,
I am trying to convert a Revit family to a GDL object, i use the BIM6x converter tool but i seem to lose the connection points that you would normally see in Revit is there a way to add these in manually?
I have experimented by trying to add the mep connection part to the objects but they seem to show in 2D but not in 3D. Am I anywhere near to the solution?
Cheers
1 Reply 1
You have to add it the way described here:
http://gdl.graphisoft.com/tips-and-tricks/how-to-make-a-mep-equipment-object
Piotr
