Creating an angled window.
Is there a way to create, using the window tool, a framed window that is set at an angle through the thickness of the wall?
I can't even think what this type of window is called.
I attached two images of what I am trying to make, but with window's instead of the wall tool.
Any help would be appreciated.
Maybe like this:
Have your thick wall with an empty opening in it the same size as your angled window opening. Place a thin wall (the same thickness as your window frame) within the empty opening on the angle, and put a window in this thin wall.
undefined
Thank you! I always forget about the empty opening window object. This worked a treat.
Just out of curiosity, do you know what this style of window is called?
No idea, sorry.
