You should try editing the spacing and number of the Primary gridlines in the curtain wall scheme settings. If you change it to the correct number of 'panels' that you require for each opening, you wont have to delete so many mullions.
It is also worth increasing the transom Frame Intersection Priority to be a higher number than the mullions, as this should remove any gaps left in the frames where the mullions were connected.
