Curtainwall Door/Window Opening Line Orientation
I've noticed this problem for a while now, and wondered if anyone else had run into it or found a solution that I'm missing.
The opening line orientation in the Door and Window Panels for the Curtain wall tool will not display correctly like a normal door or window. I cannot switch the orientation from 'hinge side' to 'handle side', nor do the opening lines even extend to the edges of the door panel. Changing the MVO options or overriding them does no good.
See attached screenshot.
Scott Graham, AIA LEED BD+C
Principal | BIM Manager
Muhlenberg Greene Architects, Ltd.
Wyomissing, PA 19610
V6.5-26.0
5 Replies 5
Erika Epstein
its in the panel settings, see screenshot
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
That SHOULD be the solution, but it doesn't work. The curtain wall door and window objects don't respond to the MVO settings or the overrides.
V6.5-26.0
Erika Epstein
You're right.
I'll report the bug.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Thanks Erika!
V6.5-26.0
Seems like this is still a bug.
Can't wait for 18 😕
Drawing 2 lines is the recommendation?
