Default settings of objects in library.
is there a way to adjust the default settings of objects in the standard Archicad library?
Not directly.
Although it sounds the most logical method, I wouldn't go down the route of extracting the contents of the library, change the default settings, then pack it back into a new lcf as you will have problems later when parts are updated.
The best ways to do it would be either to use favorites, or a visual legend as suggested in the article below.
http://www.aecbytes.com/tipsandtricks/2006/issue13-archicad.html
Hope that helps!
nope. won't be doing that.
I think the visual legend-trace reference sounds more useful.
