Door Marker Settings
I'm trying to use the ArchiCAD door marker settings for the first time and they all come out backwards in the elevation window. They're fine in plan, just need to somehow mirror the symbol in elevation. Also, is it possible to alter the size and penweight of the symbol in elevation as you can do in plan? Thanks....
4 Replies 4
Stress Co_
Someone correct me if I'm wrong.... but, I think the "backwards" opening lines are the standard in some countries (not in the US).
I've given up trying ..... and just draw 2d lines over the model or I use cadimage's door and window builder.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Seems to me that they've been fixed. Haven't had any issues with them for some time. I'm using both the US and the SE libraries.
Rakela Raul
you are correct
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
Stress Co_
Err, yea, I was looking at a project with "archicad library 9" loaded and it was "backwards" (to me). Opening another with the AC9 Special Edition Library and I see it has been corrected.
