3 weeks ago
I put doorknobs on all the door, and they are not showing up. Shut the computer down and restarted it, no doorknobs. the menu shows doorknobs, but the 3D doesn't
3 weeks ago
Hi @mukster
Check if you have the correct Model View Options (MVO) combination applied to the view. In the MVO> Miscellaneous Settings for Library Parts> Object Accesories in 3D you can set if door/window Knobs are visible.
