Double-Door Curtain Wall Wrong
"D Curtain Wall Double Door" does not trim the walls correctly -- notice the blue area in the picture. Does anybody have a fixed version of this object for 8.1? I don't know enough about GDL to fix it myself.
3 Replies 3
I belive the god one is in International lib which I use. I used this door a lot and I did not notice such strange behaviour.
(I know US curtain walls are somewhat modified from the int. ones)
I can send You the INT door if You did not get it from US tech support yet.
Regards,
Piotr
May I have this double door please
[email protected]
Does anyone found this problem:
When using this object in the elevation view some lines are missing.
