Double glazing in Archicad 22?
Hi all,
I'll just get to the point: is there any way to make windows and doors with double glazing?
I searched this online and saw that up until a certain version of Archicad (18 or 19 I think) this could be done easily from the Window/Door Selection Settings.
Is there any way to do this in Archicad 22?
Thanks.
4 Replies 4
Daniel Kovacs
I looked at ARCHICAD 19 Window Settings in the INTernational version, and it looks just about the same as in ARCHICAD 22.
Maybe you use a different language version, and that specific library part has been replaced in the new version?
Could you post a picture of this setting from the earlier version?
Was it just a field where you could define the number of glazing as a text, or did it actually show in 3D?
Thanks,
Daniel Alexander Kovacs
GRAPHISOFT
Hi Daniel,
Thanks for your reply.
This is the setting I was talking about:
I'm only realizing now that this is actually in reference to Cadimage Windows, which of course I don't have... sorry about that.
I guess there is no way of having double glazing in Archicad without Cadimage tools then?
Daniel Kovacs
Well, not in the 3D model, but if you add a Property to Windows/Doors to select the number of Glass Panels, then you can Schedule/use that information later. I am not sure what you need it for though.
Anyhow, I added this to our wishlist.
Regards,
GRAPHISOFT
Unfortunately I do need it in the 3D model, but thanks for the tip and for your help!
Regards.
