Fill not found a line 'x' in the 3D Script of file...
Hi all,
Wondering if anybody could help me with a problem I'm faced with. I'm sure there is a really easy solution or I'm doing something slightly wrong, but I've only been using archicad for a few weeks now, so I am somewhat a newbie to this program.
Everything works fine until I get to adding stairs. Which, when you have a building a few stories high is quite annoying.
Cutting the long story short. When I add in any stairs (from the archicad 15 library) I get this error report:
Beginning generation of Section/Elevation:
Start time : 28 Feb 2012 11:35:54
Number of processor cores : 2
Document name : Illston Plan Scheme 1
Processed : 62 walls 18 objects 10 columns 2 ncBeams
9 slabs 0 meshes 1 pitch roofs
End time : 28 Feb 2012 11:35:54
Elapsed time : 0 seconds
Creating section
Projection : Front view
Hidden polygon removal
Sun direction : vertical 45 horizontal 225
Finished generation of Section/Elevation.
End time : 28 Feb 2012 11:35:55
Elapsed time : 1 seconds
Fill not found
at line 89 in the 3D script of file Stair U-Shape 15.gsm.
Fill not found
at line 224 in the 3D script of file Stair U-Shape 15.gsm.
Fill not found
Fill not found
Fill not found
Fill not found
at line 913 in the 3D script of file Illston Stair.gsm.
Fill not found
at line 952 in the 3D script of file Illston Stair.gsm.
Fill not found
at line 991 in the 3D script of file Illston Stair.gsm.
Fill not found
at line 1030 in the 3D script of file Illston Stair.gsm.
Fill not found
at line 1069 in the 3D script of file Illston Stair.gsm.
Fill not found
at line 1108 in the 3D script of file Illston Stair.gsm.
Fill not found
at line 1147 in the 3D script of file Illston Stair.gsm.
Fill not found
at line 1186 in the 3D script of file Illston Stair.gsm.
Fill not found
at line 1225 in the 3D script of file Illston Stair.gsm.
Fill not found
at line 1292 in the 3D script of file Illston Stair.gsm.
Fill not found
at line 1331 in the 3D script of file Illston Stair.gsm.
Fill not found
at line 1370 in the 3D script of file Illston Stair.gsm.
Fill not found
at line 1409 in the 3D script of file Illston Stair.gsm.
Fill not found
at line 1448 in the 3D script of file Illston Stair.gsm.
Fill not found
at line 1487 in the 3D script of file Illston Stair.gsm.
Fill not found
at line 1526 in the 3D script of file Illston Stair.gsm.
Fill not found
at line 1565 in the 3D script of file Illston Stair.gsm.
Fill not found
at line 118 in the 3D script of file Illston Stair.gsm.
Fill not found
at line 481 in the 3D script of file Illston Stair.gsm.
Fill not found
at line 545 in the 3D script of file Illston Stair.gsm.
Processed : 30 walls 29 objects 10 columns 0 ncBeams
4 slabs 0 meshes 0 pitch roofs
Start time : 28 Feb 2012 11:46:38
End time : 28 Feb 2012 11:46:48
Elapsed time : 10 seconds
Projection : Perspective
Eye position : 16.8506 -77.5311 20.1906
Direction : 0.0880916 0.928984 -0.359484
Distance : 34.3498 Angle : 83
Start time : 28 Feb 2012 11:46:48
Eye position : 8.16259 -76.6247 20.404
Start time : 28 Feb 2012 11:46:51
End time : 28 Feb 2012 11:46:51
Eye position : 1.77993 -76.0319 20.3717
Start time : 28 Feb 2012 11:46:52
End time : 28 Feb 2012 11:46:52
Eye position : -3.55718 -75.6607 20.023
Start time : 28 Feb 2012 11:46:53
End time : 28 Feb 2012 11:46:53
Eye position : 1.46976 -67.3851 -2.04502
Direction : -0.12332 0.988427 0.0883466
Start time : 28 Feb 2012 11:47:51
End time : 28 Feb 2012 11:47:51
Fill not found
Fill not found
Start time : 28 Feb 2012 11:48:02
End time : 28 Feb 2012 11:48:02
Processed : 0 walls 0 objects 0 columns 0 ncBeams
Start time : 28 Feb 2012 11:48:18
End time : 28 Feb 2012 11:48:18
Eye position : 4.01076 -86.5722 -5.51881
Start time : 28 Feb 2012 11:48:21
End time : 28 Feb 2012 11:48:21
Eye position : 3.80037 -85.843 -0.441297
Start time : 28 Feb 2012 11:48:22
End time : 28 Feb 2012 11:48:22
Fill not found
Fill not found
Start time : 28 Feb 2012 11:55:29
End time : 28 Feb 2012 11:55:29
Fill not found
Fill not found
Start time : 28 Feb 2012 11:58:22
End time : 28 Feb 2012 11:58:22
Processed : 0 walls 28 objects 0 columns 0 ncBeams
Start time : 28 Feb 2012 11:58:29
End time : 28 Feb 2012 11:58:29
Start time : 28 Feb 2012 11:58:30
End time : 28 Feb 2012 11:58:30
Fill not found
Fill not found
Fill not found
Start time : 28 Feb 2012 12:00:53
End time : 28 Feb 2012 12:00:53
Fill not found
Fill not found
at line 296 in the 3D script of file Stair L-Shape 15.gsm.
Fill not found
Start time : 28 Feb 2012 12:01:51
End time : 28 Feb 2012 12:01:51
Fill not found
Fill not found
Fill not found
Does anybody know what is going wrong here?
Thanks a lot for any help!
Tom
David Maudlin
Tom:
Your problem is similar to the one discussed in this thread:
Library Parts Not Working Properly
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks David, that worked a treat!
David Maudlin
Tom:
Glad to read that solved your problem, thanks for posting back and adding the signature.
