JGoode
Floor Plan Hyperlink???
Bit of an odd one. Is it possible to create an object which acts as a hyperlink to place on the floor plan? If not possible with an object, is there any other way to create one?
Thanks!
ArchiCAD 27
Windows 10
1 Reply 1
Just type text for ... http://archicad-talk.graphisoft.com
Or even just ... www.web_address
Then when you publish as a PDF it will automatically create the hyperlink.
You can also create an object that contains the text.
The link won't work from inside Archicad itself - only from the PDF.
You can use a mobile device with a scanner to read the text from the screen and open the web site.
You can also use QR-codes.
