GDL GardenWorks Errors
I just downloaded the GardenWorks Library from GDL Central. When I place a tree from the archibam folder, and go to the 3D window, i get the following error....
Can't find picture file: RIND_GREEN, called
at line 92 of file Bush2_GWL.gsm.
Can't find picture file: F_BIRCH, called
at line 298 of file Bush2_GWL.gsm.
There are several problems with this file. You can cancel the operation with Ctrl/Command - period.
does anyone know why i am having this problem?
also. how can i insert a jpg or tif of a shrub/tree into my model?
Hello Linz
No problem in my ArchiCAD 8.1 with this Object. F_Birch.tif is a 'texture' called —many time… then many errors possible…— by the Bush2_GWL.gsm who run perfectly in my 3D Window.
Does this file —F_Birch.tif— present in your activ library?
In my library :
— The "Bush2_GWL.gsm" is in this folder : Garden Works Library/ArchiBAM/ArchiBAM_3D/
— The "F_Birch.tif" is in this folder Garden Works Library/Textures/Tree_Textures/Foliage/
