Hiding the leader of an associative label
jshuether
Is there anyway to hide the leader on an associative label?
I typically place the fixture type # next to all of the light fixtures on the reflected ceiling plans (F1, F2, F3, etc). Rather than scripting in "text2" in all of my light fixture objects, it would be so easy to use the associative label tool.
Turning off the associative label leader would also be helpful indicating partition types, because I could use a traditional partition type symbol (yes, there is a workaround by setting the arrow size to "0").
Scott
ArchiCAD 25
Windows 10
20 REPLIES 20
LiHigh
Do this:
IF LABEL_CUSTOM_ARROW THEN
delta_x=label_position [2][1]+label_position [3][1]
delta_y=label_position [2][2]+label_position [3][2]
ADD2 delta_x, delta_y
ENDIF
Howard Phua
Win 10, Archicad 19 INT
