How to define Subroutine in Master Script
On Master Script I need to do any calculations.
Whan I define subroutine, GDL says "Return without GoDub" error
GOSUB "MySub"
! defite MySub
"MySub":
RETURN
And if I write instruction END before define my subrotine, GDL say no errors, but...
2d and other script are not executes
GOSUB "MySub"
END
! defite MySub
"MySub":
RETURN
Please, help me!
How I can define and use subroutine in master gdl?
David Maudlin
Tsepov:
It looks like the GOSUB command needs an "END" to work, and as you discovered, an "END" in the Master Script prevents the other scripts from running. You might be able to accomplish the same result using IF/THEN statements, which do work in the Master Script.
You can also ask here: GDL Center - Forums.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Jochen Suehlo
You can use subroutines in the master script as well.
Try the following:
! Code
GOSUB 100
GOSUB 200
GOTO "MasterEnd"
! Here you can place an END, but you must not
100; !  1st Subroutine
RETURN
200: ! 2nd subroutine
RETURN
"MasterEnd":
The good thing is, that you can write in 2D and 3D Scripts "Gosub 100"
and the subroutines in the master script are executed.
Jochen Suehlo . AC12-29 . MAC OSX 26 . WIN11
GDL object creation: b-prisma.de
