How to insert Array Values?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2018-03-15 04:17 AM
‎2018-03-15
04:17 AM
Solved! Go to Solution.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-03-15 07:49 AM
‎2018-03-15
07:49 AM
You want an adjustable array - I think they call it a dynamic array.
As far as I know you can't have the user add new values directly to the array but you can create a new parameter that controls the size of the array.
'value' is the actual value you want to put into the array.
In this case value will be the same for each field in the array.
Unless you vary the value for each 'n' - i.e. value = value+1
DIM x [] for n = 1 to y xWhere 'y' is a new parameter that sets size of the array.= value NEXT n PARAMETERS x=x
DIM x [] for n = 1 to y xNot sure if this will help or not.= value value = value+1 NEXT n PARAMETERS x=x
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-03-15 04:45 AM
‎2018-03-15
04:45 AM
Select the row button and then insert as many as you need.
You can then select the values for each and add a default value if needed.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-03-15 06:45 AM
‎2018-03-15
06:45 AM
hi Barry Kelly !
Can I insert it in a 2D script? I want to use it to control the X coordinate but I cannot determine the number of points.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-03-15
07:49 AM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-03-15 09:45 AM
‎2018-03-15
09:45 AM
Thank you for helping me solve the problem
