vistasp
Mentor
Individual Colours in Zone Stamp Object
In my project files, I'm unable to change individual colours for different parameters in the zone stamps even if the parameters exist. However, if I open a new file with the default template, everything works fine.
It's obviously some simple setting but, for the life of me, I can't find it. Any help would be much appreciated.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
4 Replies 4
It is the Model View Options under Options/Set Model View. There you can override fills for zones.
vistasp
Mentor
Thanks Master Script but I was unclear in the first post.
Attached is a composite screenshot showing:
1. how the stamp looks when setting the category
2. how it looks once placed
As you can see, individual colour control is lost.
= v i s t a s p =
bT Square Peg
David Maudlin
vistasp:
In the Zone Stamp's Selection Settings (not the Zone Categories shown in your post), under the Zone Stamp panel check Use Symbol Colors (I checked this in 15, but should be the same in 13).
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
vistasp
Mentor
<forehead slap!>
Thanks David. It was hiding in plain sight! Sometimes we miss seeing the very things we seek the most.
= v i s t a s p =
bT Square Peg
