MEP elements connection
Dear devs/users!
I created a simple addon which places library elements especially mep elements. And i have a problem, with them. For example i place Straight Pipe, with the folowwing parameters set ConWidth_1,ConWidth_2,MEP_StraightLength,RotationAroundWAxis,RotationAroundZAxis,MEP_InsShow. It creates the good straight pipe, but I cannot connect to this with route planner and cannot create fillet/chamfer with them. So my question is that, which parameters should i set to get it working?
should i calculate gs_connection array if yes what is the structure of the array? And what else should i calculate to get it working with connections? I found this but it's not too much and it is for create gdl elements with connections. http://gdl.graphisoft.com/tips-and-tricks/how-to-make-a-mep-equipment-object
1 Reply 1
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
I doubt we will be able to help you with this here, because this seems more like a development question rather than a user thing.
I suggest you to post your question to: These forums are frequented by 3rd party Add-on developers and are monitored by the GRAPHISOFT development team. I am sure someone on these forums will be able to answer your question.
Regard,
Daniel Alexander Kovacs
GRAPHISOFT
