Learn more
Making Doors as Dashed Lines
Hi all,
Im doing a ceiling plan and we're meant to have the doors as dashed lines (school project), I cant see an option for the line type of the doors, any ideas?
Thanks,
Lachlan
5 Replies 5
David Maudlin
Lachlan:
In the Door's Settings > Floor Plan & Section > Symbol & Outline > uncheck Enable Object's Linetypes, then change the Symbol Line to a dashed linetype. But there is no way to automate this change, so it will have to be done manually as you change between Ceiling Plan and Architectural Plan.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Great, thanks for your help David.
David, providing that you don't need to combine a demo plan with the existing/new, I'll bet it could be done "automatically" with renovation filters.
Richard
AC26 (since AC6.0), Win10
David Maudlin
Yes, if the Renovation Filters are not being used, this could be a solution.
And another idea:
Select walls and doors in plan view and convert to 2D linework and change everything to a single layer with dashed linetype. Then you could place it "behind" everything else using display order.
Or: Create a .MOD file, and change everything to dashed, then put behind in the plan, or behind as a view in the layout. (You can "stack" views here.)
Or: See if your instructor will accept a light grey version rather than dashed. Then you could use a dedicated penset.
Probably another couple of ways if I think about it.
Richard
