Model Disappears When I Activate 3D Cutaway?
Hi
I have used 3D cutaway before and I have always been able to see my model in the 3D window when I am adjusting the cutaway plane.
All of a sudden now when I activate 3D cutaway my entire 3D environment goes blank. The plane is visible when I zoom right out but other than that I only see the grid.
Any help appreciated.
Thank you
Rich
2 Replies 2
Is possible that you have cut planes actives that are hiding the hole building, I had cut planes in my template before by mistake and I was having the same problem. So make sure to delete all cut planes when you activate them so you don't have my same problem.
Thank you for your help.
