jakubc7
Multileader Label 17 bug?
I was looking at using this object as a base for my own object.
However having a closer look, when the arrow is pointed UP or DOWN it seems to be slightly unbalanced... pointing sideways there seems to be no issue. SEE ATTACHED.
It my seem very insignificant, however for what I plan to use it for it will stand out ... also it's obviously unintentional and should be fixed either way.
Can anyone see anything in the code that causes the problem. The arrow poly2_b code seems to be correct ... the rest is a bit hard to follow for me.
Any help is appreciated as always.
ArchiCAD 10 - 29 | Windows 11
Lucid Design Studio | Perth, Western Australia
7 Replies 7
jakubc7
NO GOOD
jakubc7
SEEMS FINE POINTING LEFT
jakubc7
Stands out when filled and large ... would like to fix it ...
Marton Kiss
Thank you all for bringing this up. We will check and fix the object.
Marton
Marton Kiss
Chief Product Officer
GRAPHISOFT
vfrontiers
I am sure it's just me.. .I cannot get the filled arrowheads to actually FILL IN on the plan? Looks great in the OBJECT WINDOW...
It's not a RENO FILTER deal and regular label arrowheads are showing so it's not a MVO issue...
But clearly in the OBJECT SETTINGS the are filled in and going to the plan they become hollow...
(and it's not a TRACE REFERENCE issue either)...
I'll keep looking... any advice appreciated!
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
vfrontiers
Also... why does the EDITING of the arrow point move both the end and knuckle points of the leader?... very cumbersome
Duane
Visual Frontiers
AC3.14 - AC29
David Maudlin
It is a MVO issue (MVO > Override Fill Display > Override Fill Background Color). The MVO is affecting Objects (Multileader Label) but not Labels.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
