Numbering Object
Hi! I'm looking for an automatic numbering object that gives a consecutive numbering string - there was one in the Australian Essentials Library but it's not in any of the other libraries in the USA! Any advice as to where I can find it?
Thanks!
13 Replies 13
And one picture of how it is in use:
To GRAPHISOFT GDL team:
I discover a bug developing the object NUMERATOR 18. If you want to change the PEN for the NUMBERS dragging his Hotspot, everithing is OK. But if you instead pick the Hotspot and input the Pen number from the keyboard, ArchiCAD (v18_9013 and v19_5005) instantly crashes.
This Hotspot is DISABLED in the object attached on may, 25.
Njegos T
Hi andro55,
I just saw and tested your work and great job!
I have one question. Is it possible to make correction for the middle numbers to move independently of the end numbers in the x and y directions?
A_ Smith
andro55 wrote:
I discover a bug ... If you want to change the PEN for the NUMBERS dragging his Hotspot, everithing is OK. But if you instead pick the Hotspot and input the Pen number from the keyboard, ArchiCAD (v18_9013 and v19_5005) instantly crashes.
Archicad 22 - input text PEN from keyboard works fine, no crashes
AC 22, 24 | Win 10
