Paul King
Mentor
Poly2_A & Poly2_b syntax bug?
Can anyone explain why this works
poly2 4,7,
0,0,
10,0,
10,10,
0,10
but this gives "missing parameters" error?
poly2_b 4,7,1,1,
0,0,
10,0,
10,10,
0,10
Similar result with Poly2_A
Is this syntax incorrect or is there a mistake in the GDL manual?
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-29 | Twinmotion 2025
Windoze 11 PC | Intel Core Ultra 9 285K | Nvidia Gforce RTX 5090 | 64 GB | 2x4K monitor extended desktop
3 Replies 3
PAUL,
I notice you are missing the masking values
in the POLY2_B command.
The POLY2 command does not require masking values.
I know you know this
Peter Devlin
Paul King
Mentor
Arrrgh!
Obviously quite right
Hate the way the manual is laid out - it assumes you read from front to back in sequence rather than skipping straight to the bit you wanted - you have to back up to the Poly2_ command to even find a definition for "status codes". And the link to "additional Status codes" does not actually list any - you have to back out of that & go back to main contents listing to find them.
Not ergonomically designed at all
Thanks for pointing out the obvious!!
PAUL,
Are you like me and many others that would like
GS to publish a hard copy of the GDL manual so
you don't have jump around inside a PDF ?
I wonder if you can stuff the ballot box in the wish list
Peter Devlin
