Preview picture GDL
Hello everyone,
Please, i would like to personalize the previwe picture of my .gsm objets. I'd already copy and past my image in the previwe window but nothing is happening . is there some type or specific size of images ?
Thank you.
4 REPLIES 4
I use a screen capture for the copy and then paste that in.
Copy and paste from within Archicad doesn't work as it doesn't create an image that can be placed.
It just copies the elements that can be pasted elsewhere in Archicad - not an image.
There used to be a registry switch (Windows) that would copy as an image as well but I think that may have stopped working.
Not sure as I just screen capture.
David Maudlin
Ataf DJEFNI:
I usually create a small (200x200 pixel) photo rendering of the object from the object's 3D View, then copy & paste that into the Preview Picture. The image size could be larger.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks for your answer, 'im gonna try it .
Okay for the signature in my profile.
David Maudlin
Ataf:
The method is described here in the help files: Preview Picture.
Thanks for adding the signature, you should also add your ArchiCAD version.
