Problem with Openings
Hi everyone.
Has anyone experienced a series of errors associated with the application of a standard opening onto a wall in ArchiCad?
Whenever I try to apply any kind of opening from the standard AC 13 library I'm hit with a wave of errors like the one I'm attaching here.
Again, this is an unaltered library object that I'm try to apply to a standard wall.
3 Replies 3
Have you removed any of the default fills from your project?
Not that I'm aware of. I have not been adding or subtracting from my libraries. Been pretty much working off of the standard AC-13 object library.
Doors work, just not the windows.
I can't even view them in the object info dialog window. It will show up in plan, but then it starts throwing a fit when I click any of the 3-D Views.
David Maudlin
Fraydo:
See this thread:
Library Parts Not Working Properly
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
