Setting FM Values
This is probably quite simple, but this late in the day it's killing me. I want to set one of the FM parameters using the following line:
FM_InventoryNumber = sPrefix + sGauge + sSuffix
Assume all of the variables are set to string values. Where should I put this line? I put it in the Master Script, but it doesn't fill the parameter. I tried the Parameter Script, but that didn't work either. Where should it go?
3 Replies 3
Put the keyword PARAMETERS in front of the line in the Parameter Script. See the GDL Reference Manual (8.0/8.1) page 108 - section 10.2 ... or the old 6.5 manual page 163 section 9.2.
HTH,
Karl
Rob
Jay,
just put this line into the parameter script:
PARAMETERS FM_InventoryNumber = sPrefix + sGauge + sSuffix
that will do
(assumingly sPrefix, sGauge, sSuffix are string variables)
::rk
I knew I was missing something stupid!
