scottdlieb
Sliding doors appear as single lines
All of the sudden, my sliding doors (not swing doors) are appearing as simplified single lines. I feel I may have accidentally selected something. How do I get them to appear similar to my swinging doors?
3 Replies 3
felcunha
Take a look into your model view options
Felipe Ribeiro Cunha
AC 26, macOS Monterey
Or if it is just some doors then look in the settings for those door objects.
You may be overriding the MVO settings for level of detail for just those objects.
scottdlieb
Thanks for the answer, by the way. I just migrated from ArchiCAD 9 which I had been using since 2003. There are A LOT of really good things in 22, but it's also a little overwhelming. As you mentioned, it's because of "model view options". I haven't had the time to dive into exactly what that means, but when I chose the "scale sensitive" option, it returned my doors to the preferred 2D look I wanted.
