Text into a section
Cosminn
Hello everyone,
I created a 3D object and I want to see it in section together with a text.
How can I write a script for a text to be displayed into a section, like a text from a grid tool. I think the script should be write in -3d script-. I've used the 3D text elements:
Text
Richtext
but seems to be other texture. Is there any chance to do that?
Thank you.
Sincerely,
Daniel
David Maudlin
Cosminn:
You can use the Text command to create 3D Text [TEXT d, 0, expression] (this is used on the Text 3D object). But there is no way for the Object to know which direction the section is taken for orientating the text. I do not understand "but seems to be other texture".
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Cosminn
Thank You David, for your prompt reply.
Please see attached
Sincerely,
Daniel
Cosminn
I'll add my signature to my profile as well, thank you.
Sincerely,
Daniel
