I have approached this a bit differently...
Instead of using the OVERSIZE function, I re-set A and B to the FRAME size without the trim.....
1. Create window with TRIM and everything else...
2. Know the size of the FRAME; for this discussion we'll say the window is 4'-0"w x 5'-0"h (sorry for feet and inches)... and our trim is 4" all around.
3. Our entire GDL would show 4'-8" x 5'-8".
4. When the GDL is completed by archiCAD, open it up and change A to 4'-0" and B to 5'-0".
5. In the 3d Script, change the MUL statements to the respective values (so, Mulx a/4'-8" will change to mulx A/4'-0", etc.)
Now your window callouts will be the actual size of the window and NOT the OVERALL size w/ trim; which is more tradional here in the US.
This will be reviewed at ACWest / Adv Modeling techniques!
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
