Using global id as a start for numbering in object
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2009-12-08 02:08 AM
2009-12-08
02:08 AM
for j=1 to n-1
add2 a/n,0
text2 0,0,j+start_num-1
next j
del j-1
start_num is an integer variable.
It works
if use_glob_id then
start_num = glob_id
endif
When including this code in the Master Script, despite whether use_glob_id = 1 or 0, I get the incompatible expression types error. What do I have to do to get the numerical number from the glob_id into my text to begin the numbering of my object?
Side note: I've always wanted to be able to add select variables of an object to the Info Box to minimize the opening and closing of dialog boxes.
ArchiCAD 25
Windows 10
Windows 10
2 REPLIES 2
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-12-08 03:32 AM
2009-12-08
03:32 AM
The GLOB_ID is a string rather than a number.
So I would say you would have to use the SPLIT command to filter out the number component.
However your GLOB_ID will always have to be in the same format - the user can type what ever they want in there.
Type something other than what is expected in the ID and the script won't work again.
I am guessing you would rather use the ID in the info box but you will be better off creating an parameter (integer) in the object that means only a number can be used.
You can even control the range of numbers allowed to block out negatives or zero values.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-12-08 06:59 PM
2009-12-08
06:59 PM
I figured it was the SPLIT function, I was just writing it incorrectly. I originally failed to put '%n' in quotes. After a quick check of the GDL Cookbook, I found my error.
The working code is:
if use_glob_id then
x=SPLIT(GLOB_ID,'%n',start_num)
PARAMETERS start_num=start_num
endif
if use_glob_id then
endif
ArchiCAD 25
Windows 10
Windows 10
