sarahric
Wallhole gap above doors
To provide what is required of me in the door schedule, I have created doors with a unit size, then a larger wall opening size.
This can be seen in 2D. In 3D however, the wall lining covers the opening on the sides, but not at the top. This means I always have a gap showing on top of the door. Why is this happening at the top only and how can I remove it while still showing the correct in the door schedule?
ArchiCAD 18/Windows 7/16GB Memory/i5 3.2GHz Processor/NVIDIA GeForce GT 610
6 Replies 6
In the Door settings there is "Opening Oversize". Try to use it.
sarahric
Using the opening oversize doesn't help at all, it also creates a hole in the wall in 3d. I don't want the hole to show.
What I don't understand is how the gap on the sides doesn't show, but the gap at the top.
screenshot attached.
Erika Epstein
Cant' read the blurry image. Can you repost a screenshot of just the settings tab at readable resolution?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
sarahric
hopefully better
Erika Epstein
"To provide what is required of me in the door schedule, I have created doors with a unit size, then a larger wall opening size"
I thought it would include the oversize dimensions. You can set them to be equal sides and top, or set them separately. Can post a screenshot of the oversize opening tab settings/
Why do you need both the unit size and the oversize? Good reasons to have both, but what are yours?
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
sarahric
The builder wants to know the unit size for the window manufacturer, and the wallhole size for the carpenter to make the opening which includes allowance for movement, etc, in this case is 13mm eitherside of the unit and 28mm above.
I need to therefore list both the unit size and the wallhole in my schedule.
The oversize opening I have always set as 0, instead using the wall hole to create the opening.
Even if I change to using the oversize setting, in 3D i get a gap on both sides and above.
If I use the wallhole setting, I only get the gap above. My question is why? and how can I make the gap not appear?
Opening oversize does not appear to be the solution, unless you can cover the gap in 3D
