Why 3D object displayed in square?
Hello !
Objects are not displayed properly in the 3D view. Which setting should I change?
See the attached image.
Thank you.
Post moved.
Please do not post everything to 'Archicad+' unless it is a discussion about Archicad itself.
Please read the forum section descriptions to find a suitable place to post.
Look in the Model View Options for a setting regarding Level Of Detail (LOD) for objects.
If it is not in the MVO settings then it will be it the object parameters.
Thank You Barry,
it works !
Indeed it was necessary to select the view (All 3D), then go in documentation / model view to pass it in execution. Do the same thing in 2D view.
Thanks again !
