Sam Karli
XML extension: how to make it work?
I'm experiencing with the xml extension, but even cannot start it.
What's the problem with the following code (being in the Parameter script)?
channelTest = OPEN ("XML", "Teszt", "wl")
OUTPUT (channelTest, "CreateDocument", "", "Teszt")
CLOSE channelTest
GDL/Python/C++ dev
4 Replies 4
Jochen Suehlo
Read this first, maybe it helps:
http://gdl.graphisoft.com/tips-and-tricks/how-to-use-the-gdl-xml-add-on
Jochen Suehlo . AC12-29 . MAC OSX 14.4 . WIN11
GDL object creation: b-prisma.de
Sam Karli
Thanks for Your help, not too much. 😞
It describes reading a (prepared) read-only doc. My problem is with creating a new xml by the OUTPUT command.
Such a poor documentation.
GDL/Python/C++ dev
Jochen Suehlo
I haven't try, but I think the Script should be in the Master and OUTPUT has to be without brakes, like
OUTPUT channel, "CreateDocument", 0 , 	"Par_Set"
Sam Karli
Indeed.
This works:
ChannelTest = OPEN("XML", varFileNameWithFullPath , "wf")
OUTPUT ChannelTest, "CreateDocument", var1, "Teszt"
input (ChannelTest, "NewPositionDesc", "", varDesc)
OUTPUT ChannelTest, "NewElement AsFirstChild", varDesc, "Coord"
input (ChannelTest, "MoveToNode ToFirstChild", varDesc, var0, var1, var2)
OUTPUT ChannelTest, "NewText AsFirstChild", varDesc, GLOB_INTGUID
OUTPUT ChannelTest, "NewElement AsFirstChild", varDesc, "X"
OUTPUT ChannelTest, "NewText AsFirstChild", varDesc, str (SYMB_POS_X, 8, 3)
OUTPUT ChannelTest, "NewElement AsNextSibling", varDesc, "Y"
input (ChannelTest, "MoveToNode FromNextSibling", varDesc, var0, var1, var2)
OUTPUT ChannelTest, "NewText AsFirstChild", varDesc, str (SYMB_POS_Y, 8, 3)
CLOSE ChannelTest
But in the GDL Reference guide OUTPUT stands with brackets, I've checked.
Many thanks.
GDL/Python/C++ dev
