joelfeyaerts
curtainwall - entrancedoor: removing boundary
hello,
does anyone knows how to remove de boundary frame under an entrancedoor in a curtainwall??
and than if possible place the door at the same level as the boundary
3 Replies 3
Dennis Lee
I had no luck making it invisible frame or 0 thickness frame, so I usually give that frame a 1/4" to 1/2" thickness for the threshold. If it has no threshold, 1/64".
After you adjust the thickness, you need to adjust the adjacent vertical frames intersection priorities to make them join properly.
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
Making the lower frame invisible is the way to do it. To get the door panel to extend all the way down, select the invisible frame and change the 'panel slot dimension' (d) to a minus figure equal to half the width of the frame.
The priority of the vertical jambs will need to be increased to a figure greater than that of the boundary frames (usually set at 15) in order to get them to extend past.
joelfeyaerts
Thx Peter,
this helps me a lot:)
