everytime i use door or window i got this error msg
any idea what happened? i click the window and switch the view, and I got this error msg and apparently I cant use window/doors.
quote:
Fill not found
at line 96 in the 3D script of file D1 Combi Commercial Door 10.gsm.
It affected to all doors/windows
Line 96 refers to a fill used when displaying the door in section.
In the 3D representation settings there is a parameter called
Frame Section Fill which is apparently missing. Select the door
while in the plan, go into it's settings, find the parameter,
and select an alternate fill.
Peter Devlin
I usually go one step further. I Open the object(window or door) and in the parameters I find the section fills and change them to something different (as Peter said). That way if I have to place a different version of that same window I don't have to change the settings again because it's changed within the objects internal properties. Then, save it as a favorite and not have to worry about it again.
Doug
