i need help finding a sofa\chair
hi i am looking for an object a chair or a sofa.
from where can i download?
i am using archicad 11
What do you want beyond what is in the 11 library, or in the GDL Object Depository here? There are 100's of 3D download sites (fewer GDL ones) so this is not an easy question...
Karl
Dwight
You will find the Archicad sofas under the chair icon [objects] on the toolbar,
Or search the library using the built-in object finder. This can be easier if you are unfamiliar with the folder hierarchy of the library.
Dwight Atkinson
