insufficient sides in the generator. at line 4746 in the 3d
Brand new on this forum so I hope I am posting on the right category.
I am having an issue with my project, every time I open the 3d window, a report appears showing a serious of problems stating: “insufficient sides in the generator. at line 4746 in the 3d script of the WallHoleCUt.gsm.”
Does anyone know how to solve this problem?
David Maudlin
bress88:
The WallholeCut.gsm is a macro, so it could be called by any number of library parts (but based on the name probably a Door or Window). You will need to isolate the problematic part(s), then try to discover which parameter is leading to the error. To isolate the problematic part, try using the heavy Marquee to reduce the model by halves until you have found the part, then try changing its parameters to see which one is generating the error.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
