line geometry
Here is the code I am working with
mul2 A/0.862105, B/0.862105
add2 62'-9.5004", -42'-7.8959"
pen 11
line_property 0
line2 -61'-4.5298", 45'-5.8370", -59'-11.5593", 44'-0.8664"
line2 -59'-11.5593", 44'-0.8664", -61'-4.5298", 42'-7.8959"
line2 -61'-4.5298", 42'-7.8959", -62'-9.5004", 44'-0.8664"
line2 -62'-9.5004", 44'-0.8664", -61'-4.5298", 45'-5.8370"
Are these x,y coordinates? I need to relocate the square in relationship to the other objects and don't know if this is how I make that happen.
Working with this automatically generated code is going to be a pain in the neck. It is MUCH easier to just script a rectangle with something like:
Rect2 x1, y1, x2, y2
The arguments represent any variable or constant values you want to use to define the coordinates two corners of the rectangle. A common form would be:
Rect2 0, 0, A, B
Which starts at the local origin and uses the default size parameters (adjustable in the Info palette).
