masking errors using CUTPOLYA and REVOLVE
I am trying to punch holes using CUTPOLYA in a dome shape created with the REVOLVE command. I cannot mask the sides of the cut holes. I cut the same holes in a flat prism and the sides masked properly, so the problem must be in the revolve command. No matter which masking value I use I cannot see the sides of the hole. Any help would be appreciated.
Steve
11 Replies 11
My progress
open new profiler object
create new parameter name issolid type bool
setup issolid on
Julia,
Was the bench top made with REVOLVE
or was the basin made with REVOLVE
or both ?
In the description of the REVOLVE command in the manual
it says "mask: controls the existence of the bottom, top and
(in the case of alpha < 360° ) side polygons."
If the side polygon is omitted the object will not be solid.
Thank you,
Peter Devlin
