rozky
request in parameter script
Hi
is possible to create paremeters value from reguest ?
DIM DATA []
n = REQUEST ("ASSOCEL_PROPERTIES", "code", nr, data)
IF nr = 0 THEN
values "code properties" "No properties"
ELSE
values "code properties" data [n_properties]
ENDIF
Thank you in advance
Ryzen Threadripper 1950X - 64GB RAM; NVidia GTX 1080Ti ; Windows 10 64bit; AC10-AC23 (64bit)
Gergely Feher
This request can not be used in parameter script.
Check request usability in parameter script here:
http://gdl.graphisoft.com/reference-guide/request-options
_________________
Gergely Fehér
Team Leader, Library Team
GRAPHISOFT SE
