Display malfunction of Graphisoft ID dashboard
Learn more
scale bar query
For planning drawings I am required to put a scale bar on my location plans (typically at 1:1250)
If I use the standard scale bar in the object library , it is too small at such a scale.
Any workarounds?
Thanks in advance
4 Replies 4
There is an object "Scale 2 11.gsm" (part of the free ACE-Library-V1.lcf......=246MB), which has a parameter to scale acordingly to the drawing scale.
thanks for that.
I downloaded that file some time ago, will have a look.
rocorona
With the standard one, you can change A and B sizes to adjust the appearance. If 'A' is more than 30 meters (it can be 30.001 or more) the divisions are in steps of 10, instead of 1. If the 'A' size exceed 300 meters the divisions are every 100 mt.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
A 20 / 50 /100 m option would be nice too!
