Alex Smith
surboard and skateboard objects
Does anyone have and surboard and or skateboard object that they can share?
6 Replies 6
Stress Co_
Skateboard HERE
Marc Corney, Architect
Red Canoe Architecture, P. A.
Alex Smith
Stress wrote:
Skateboard HERE
Thanks Marc
Do you know if there is a way to separate the images of the board, so there is just one skateboard?
Stress Co_
Opps. sorry. Didn't realize the object was two boards.
I didn't see an option in the parameters to turn one off... so you could do it with SEO (Solid Element Operation) workaround.
Use the slab tool to draw a "box" around the board you want to eliminate.
In SEO, Select the Skateboard object as the "target" and the slab as the "operator". Use "subtract" as the operation.
Hide the slab's layer.
Select and view the skateboard object in the 3D window (Parallel projection settings-Viewed from the top).
Go: File> Libraries and Objects> Save 3D model as...... "an object".
Maybe easier to look for another board?
Alex Smith
Thanks Marc
I will give it a go
Cant seem to find any other skateboards
Regards, Alex
Alex Smith (Director)
CSA Architects Pty Limited
Nominated Architect Alex Smith Reg. # 5473
185 Old South Head Road, Bondi Junction NSW 2022
Telephone 61 2 9389 4055 Facsimile 61 2 9389 4077
Website: www.csa-arch.com.au
Email [email protected]
Stress Co_
If all else fails... I just found THIS site. Search, they have surfboards too.... but ya gotta pay
Alex Smith
Thanks Marc
Your method worked to separate them
much appreciated
Regards, Alex
