the inclined lines in objects and morphs elevation's view?
Dears is there any way to hide this inclined lines in the elevation and section view for in documentation?
photo attached
1 REPLY 1
If it is an object there is not a lot you can do - that is how the object is scripted.
Except convert it to a morph.
Once it is a morph you can select sub elements (CTRL+SHIFT) or switch to the sub-element selection cursor, select the morph lines and change them from a 'hard' edge to 'hidden' in the morph settings (or info box).
