v13 GDL objects not opening in v12
Hello, This is probably pretty trivial & apologies if its been on before.
I have created some objects in v13 which arent even visible in loaded v12 libraries. Therefore not available in v12.
when dragging & dropping from explorer the error message:
"Drag & Drop did not succeed"
"Either the dropped object is invalid or the web pluginversion is outdated"
Can you please help me?
You can't use V13 objects in V12.
They arn't backwards compatible.
