Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
No object Library
Just downloaded archicad 13 student version and there are no objects in my object library.
My friend downloaded the mac version and he has it on his.
I searched for updates and it said the library needed updating which i did and it provided me with some stuff but no objects.
I hope someone can help
Thanks
2 REPLIES 2
Hi Chris,
Check in the 'C:\Program Files\Graphisoft\ArchiCAD 13\ArchiCAD Library 13' folder and see if the file 'ArchiCAD Library 13.lcf' exists. It should be 75.6mb in size. This is the library that ArchiCAD loads.
If it is there, I guess all you will need to do is go into the library manager in ArchiCAD (under File>Libraries and Objects) and 'add' the above file.
If the file doesn't exist, try reinstalling/repairing ArchiCAD.
Thanks Peter,
I reinstalled and that sorted it out.
Chris
