ArchiCAD - electonic signature
Hi all,
I'm trying to find out a way to protect my work, so when I deliver a project in .pln or .pla format, to be sure that only the firm I'm delivering to, is using my plans.
I have the following problem:
I made a project, and I must deliver it to it's owner, in .pla or .pln format. So far so good. But I want to be sure that there is a way to put a so called "electronis signature", in my plans, so that noone can delete it, and when I see a plan, I can verify that is not mine, and they didn't just give it away to anybody.
So...I'm asking you: do you know anything that could help me in this matter?
So I can give the project, anyone can work on it, but still, I can verify that it is or isn't mine?
11 Replies 11
Haneef Tayob
Check also with the local architectural institute.
They may have some guidelines or even client-architect agreements which cover issue of copyright.
It's always going to be a tricky issue to deal with.
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
Thank you all for the replies.
Untill now, I have not found any particular method to use to obtain what I want.
Finally, we used the simpliest and logical method...to sign an agreement.
Again , thanks for your interest.
