dominicus
ArchiCad open recent at startup ?
Last week when I installed VBE for ArchiCad my ArchiCad broke somhow and doesn't show the "open recent/open new/browse" dialog anymore - instead it starts a new projekt each time.
Has anyone stumbled upon this before - is there a setting that can be changed?
Sincerely,
DB
db-architects ltd
Dominicus Björkstam
Finland
AC 24 latest build, localized FIN version
Hardware MacbookPro 15" i9 + 32GB Ram + Windows Desktop (win10)
4 Replies 4
David Maudlin
dominicus:
From the Help files:
If you don’t want to see the Start ArchiCAD dialog box every time you start the program, disable it by checking this box. To enable it again, use the File > New & Reset All command.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
dominicus
Thanks for the fast reply.
However if I go to File>New
it list options: new projekt och share teamwork project
Don't have an option reset all commad
Sincerely,
DB
PS. I just added the data to my signature
db-architects ltd
Dominicus Björkstam
Finland
David Maudlin
Dominicus:
Try holding down the Option key while selecting File > New, it should change to File > New & Reset All.
David
dominicus
Thanks - you just saved my day 😉
That was it and now it starts up normally again!
Sincerely,
DB
db-architects ltd
Dominicus Björkstam
Finland
