Archiforma doesn't load
Hello!
I don't understand why Archiforma doesn't load. I just downloaded Archiforma for Archicad 12, the demo version and I moved it in the Add ons folder, as indicated in the installation guide.Still, afer I opening a file, there is no pallete, toolbox or anything like that, though I've checked the Add ons Manager and there it says that Archiforma is loaded. Where is the problem? Or how can I start this add on? Thank you
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
probably you are using a Custom Working Environment.
Just select/active the Standard WE Profile or add ArchiForma to your custom profile.
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
@Fabrizio: Sorry for the delaying the feedback; thank you for you reply, but my work environment is set to standard and still doesn't work. I had another friend (who also uses Archicad 12) to try and install it on his computer, but the result was the same.
