Showing results forΒ
Search instead forΒ
Did you mean:Β
Search instead forΒ
Did you mean:Β
Can someone remind me how to locate & install fonts
Bought a new machine and noticed after installing AC17 and opening the
job that I'v been working on that the font I used (century gothic western) has
a check mark in front of it and is in brackets. I believe this means it isn't loaded. It has been almost 5 years since I have had to do the font thing and don't remember where it resides, or how to install if I can find it.
Do I have to start loading older versions of AC that I had on my old computer? I don't remember if AC had this font or not and if it didn't have it I can't remember where I got it.
1 Reply 1
You can download it from here:
http://font.downloadatoz.com/font,70781,century-gothic.html
INSTALL: How to Expand Century Gothic Font Archives
1. You will need a special program to open files with the .zip extension. WinZip is one such program.
2. Once WinZip (or another similar program) is installed it can be activated by clicking on the downloaded .zip file.
3. Click on the font to get a copy of it out of the archive (it's called expanding the archive) and on to your hard drive.
4.See the instructions, below, for installing the font once you've expanded the ZIP archive.
How to Install Century Gothic Font:
Download the font file Century Gothic.ttf; Unzip it if it is ziped; then:
1. Windows 7/Vista: Right-click on the font files > "Install"
- See more at: http://font.downloadatoz.com/download,70781,century-gothic-for-windows.html#sthash.VKdPgYMz.dpuf
